41 sprocket
Chbronco
5
Going to order a #41 50 tooth sproket,for a 49cc 4 stroke kit.Its the 9x80 gear ratio one,want top speed no faster than 30 mph will this #41 sprocket work with the stock gear?
Chbronco
5
Guess #42 is for a 415 chain,now would a 50 tooth sprocket get me the desired speed?
Sidewinder Jerry
2,009
953
Rockwood, TN
You need to provide better information. What 49cc 4 stroke kit? What size wheels are you using? Do you mean the current total reduction is 9.8:1? What is the total weight (You and the bike)? Do you have steep hills or is it mostly flat?
  • Like
Reactions: indian22
Venice Motor Bikes
Mar 20, 2008
7,275
1,814
Los Angeles, CA.
Those 49cc 4-stroke kits are seriously lacking in power!!! The average speed of those kits is only about 25 MPH.
The stock size rear sprocket is usually the best compromise of power & speed.
Using a bigger sprocket will give you more hill climbing power but will reduce your top speed... using a smaller sprocket will do the opposite.
& yes... #41 will work with your #415 chain
  • Like
Reactions: indian22
