4 stroke sparkplug cap broken
scar11211
7
8
37
hi i removed the cap to take the spark plug out and the inner coil got stuck on the crown of the spark plug question i have is can i unscrew the cap and use my ngk cap from my 2 stroke,thanks
Greg58
5,114
2,045
Newnan,Georgia
If You have enough wire cut as close as you can to the boot and screw the boot on, as far as unscrewing the old give it a try.
Greg58
5,114
2,045
Newnan,Georgia
Yes the NGK plug cap will work as long as you have enough wire, the NGK cap is usually slightly longer so this almost always works. You learned a lesson the hard way, always twist the cap back and forth while pulling it off, never pull on the wire.
