4 stroke Heavy Huffy Honda build
brentemmons
I am going turn my 2 smoker daily driver into a 4 stroke with a tork coverter trans.I have put over 500 miles on the bike and have worked the bugs out,I want a little more tork and gearing for the hills then have high speed for the long flats.I have burned up my 2 stroke from this and trying to see how much power I cant get out of this little motor.It was a great way to get into building these bikes.
dnut
I am going to leave the bike the same and have a cool idea for a unie strut mount with a adjustable motor plate to adjust chain but here is my pictures of the parts I have so far.
I am not going for light weight,I just want to pull the rope and go.My plans are to use the bikes tank,get rid of the stock tank,air filter and muffler.Then run a 1" straight pipe to the rear with a slash cut.
I was wondering if they make a 12 V charging coil for this motor or if I will have to make one fit?
I will need a good air filter to put on this and I will do the header in flex pipe then run solid pipe down the frame,I think 1" would work fine.I am looking for a steady 40 -45 mph with good hill power as well then also the mpg should great.This is my first 4 stroke so I went with honda as I was a service tec for them in the late 90's.Also I got the motor for $57 on Ebay cant go wrong for that.The tork coverter trans is new but will be worth it.
.shft.
I took out the 2 smoker then tried to put the honda in,going to have to be creative with this one.The cvt trans will also be a problem as the chain comes out from under the cover behind the clutch and not from the back of the housing like I had planed.Also you have to tilt the motor to a 10 deg angle to make it fit the frame at the bottom.I might modify the frame to make it longer then it would fit.
I should have more pictures later,I cant wait to see this go.I have to go do that 4 letter word thing called work this morning then its 2 day off to play with my new toy.
dance1
I've benn looking at the same engine trany combo. Nice find on the bullet line it was the cheapest i could find.
Got my motor in the frame today and set up drive.The spocket is not in line but I have a good idea on that.The motor just fits but it will be worth the hassle.
I think the uni-strut mounts will work good,I am going to trim them up a bit then paint them.The motor has about 1/2" of room on top,plenty of room for the muffler.I cant wait to try this out.I was thinking about using the carb from my HT motor with a bigger jet and takeing out the govener.
dance1
I had some time today and had to got into work to do my chores so I put the bike in my truck.I remove the stock muffler and broke both studs off so I drilled them out.Next I made a exhast manifold plate and tig welded the pipe on.After that I placed the motor in and marked the mounts removed them and drilled them out,cut the mounts to size then fitted the motor.
dance1
My clutch backing plate needs to be modified so I can move the chain sprocket to the back of the plate not on the inside bye the clutch so my chain will line up.I noticed the build Scotto is doing has the right plate cofiguration so I might just get the right one,but what fun is that.Figureing out things and making them work is were all the funs is and it makes you think.I should have some picture soon but was pouring when I got home.
Bad news my motor wouldnt start on the wood splitter(5hp briggs 25 years old) so I took the honda off the bike to get it going.It worked out great and runs sweet,now I think I will rebuild the Briggs 5 hp and make a all american heavy huffy.The bike,motor and drive was made in the USA why not.
dance1
The only thing wrong with the motor is it has no spark and the sump gasket leaks so wile I am in there I will remove the govenor and put new gaskets and rings in it.I also noticed it is not as wide or as tall as the ohc honda.
dnut
I will do the electronic coil for better spark,3 angle valve job,heaver spings and I have a idea about the intake and carb setup from my china girl motor with a manic intake I have.The carb has got to be better than the briggs and I will just drill the jet out untill it runs good.
.wee.
