StevenMain
The port arrangement with more thought out ports topped out at 49.25 on the same hill. But my tire pressure is kinda low in the front though tonight, has been leaking a bit , but has much more mid range and can actually sustain better flat ground speed. Average speed on flat ground is about 45 -46. It's a success I'd say since I'm definitely getting more useful power. As for VMB getting 54mph.. no idea how that's done because I've done everything I can think of.
EDIT: I totally forgot when I was putting her together I took note of the piston at BDC and the crown was blocking litterally half the transfer port. So I need to try Sbest suggestion of the second base gasket, also going to put maximum ammount of ramp on the piston I can get away with, anything to get that transfer port more open will likely give me a top end boost. Maybe even go as far as 3 base gaskets and no head gasket.
