1st china girl motorized bicycle 'fatboy slim'
junkyard
well i finally get to post some pics.....yay!
rims and brakes came from kids x games motobike
frame forks came from shamu bike
added jackshaft with steel rear hub and rear dropouts
im waiting on my kit to arrive .....should be here in a few days
ill have more pics soon
Re: 1st china girl 'fatboy slim'
few more pics
nice looking bike JY. Got some great idears there. Good to see disc brakes front and bak. stop u in no time. What engine u gona put on it?
got my kit today
was a tuff fit but i found the sweet spot and it looks good so far
this was just to get the placement of the motor....ill be making new mounts with bushings
well i tried to put the carb on the intake and there was no room at all so i needed a 90 degree elbow
i read a post that said you could use plumbing supplies so i went to the shed and found a 90 degree fitting used to install a shower head
the end where the shower pipe goes has threads and after grinding them down a bit it slid right onto the stock intake...i ground it down a small amount a few times til i got a tight fit.......then i smoothed the outside of the end that the pipe gets soldered into and that slid right into the carb
i was gunna JB weld it but figured a set screw couldnt hurt so i drilled a hole and threaded it then made a countersink in the intake and ground the screw to a point to fit into it......holds it nicely but ill probly JB weld it also once the build is done and im ready to start riding it
Yeah, I think you'll need to have some kind of sealant on it so that you have no air leaks.
Nice build ya got goin there.
yea plus its still kinda threaded......i read on another thread JB weld works good....cant remember if reg or quik has the higher temp tolerance
I would use some kind of silicone, I'm not to sure how the JB weld would hold up on your intake. It may or may not, but I would want something on there that would be a little easier than JB weld to remove and re-apply as needed.
few pics with the carb and unfinished muffler
muffler mock up done....only needed 2 3/4" 90* emt elbows
sorry for the mess......kinda how i got this name....lol
its not welded yet....just taped together
more pics
still not done....mounts and muffler are tacked in place....so far so good
with the urethane bushings i can pull the motor to the side just enuff to get the spark plug cap off
pedal chain hits the clutch case a bit but i dont plan on pedalling much...lol
everything is in place and ready to weld up
few more pics
was gettin dark so the pics arent great
lighting is everything with this cam......and even then the pics arent great
I agree with Neat, the fat rubber looks great. Cool build so far. My suggestion: you need another skull, on the air filter.
well ive been out of the loop for awhile
after the test ride the bike ended up in the shed
broke it out this week and gave it a kick and to my surprise it started right up
took it for a spin and it rode great
now to tear it down get some paint on the new parts and get back on the road
i cant believe its been 3 yrs
time sure flies
