Alright so I went to grease up the bucking bar, clutch cam recess and the gears under the clutch cover. So when I took off the cover over the drive sprocket, I noticed a small area of the cover was grinded out from the chain. While I was doing that, I noticed a bit of oil coming out behind a screw from the magneto cover, so I unscrewed just that screw and lots of oil spilled out from there. It had to have been flooded inside that thing, not sure if that is normal or not.
When I took off the cover over the clutch gears, a screw/lock washer fell out. It was the large head flat head screw that apparently goes into the pinion on the drive shaft and that screw had been grinding at the cover for quite a while and a good 3/8" of the threads on it were smoothed. So I cut off the smoothed threads and I got it to re thread back in. I made sure to put a lock washer on that and tighten it really well. Then I finally greased those gears and put the thing back together.
The result: no more squeaking and the bike can glide much much more freely. However, I encountered that crunching noise I had described earlier again, but it was actually the chain bouncing around, so I just need to re-tension it. I have yet to test the engine again, kinda rainy around here.
I'll keep your suggestions in mind about four stroking and testing compression once I run it. And I won't bother with new carbs stuff, thanks for info on that
SomeGuy
SomeGuy
