Goat Herder
Gutter Rider
Grab a dirt cheep micrometer from Harbor Freight. Use this....
https://www.google.com/search?q=spo...fficial&client=firefox-a&channel=np&source=hp
There are tons of these calculators! A reputable spoke merchant can help too.
Now here is the simple part and it is really that simple.. Measure your hub flange and get the inside diameter of the rim your done.
If you are using a new rim they often have a label on them or can be very easily Googled.
Here is the part I figured out on my own. Proper measured spokes do not have to be cut lol. I don't use a truing stand. How you ask? Well I had a extra wide rim for one. It was also new. Did a slight adjustment at the rim seam nothing else.
Proper measured spokes are all the same length ... If you are to make a ton of laps around the wheel and observe the spokes coming through the nuts on the end. Keep them the same. Just be patient..
My rear wheel was a good square wheel. The front one needed to be dished to fit my down hill forks a tiny bit. I mounted those into the forks and worked it over.
Rear wheel simply put it together and it was a perfect fit.
Proper preload is key to a well built rim. Spokes that are loose break and can also get looser quickly . The uni-body structure is gone then as well. When they are done right they WILL stay tight.
The very first wheels I ever built have never needed a follow up . They are Holmes Hobbies Sapiens. In wait for it.....
None other than 13 gauge spokes tied up to a 10+ horse power motor with over ten thousand miles on them. Still as tight as day one.. Not a thing wrong with them. I had a ton of doubt yet they have been simply flawless.
Some of the cheep Chinese hub flanges are sometimes too thin on some hubs. That can be troublesome as they will put unnecessary stress on a spoke at the bend where they sit.
I was very lucky my hub flanges are perfect.
The fellow at Holmes makes custom wheels for high power hard torque electrics etc and no body is complaining that I ever knew of? His passion is the machines that we are playing with! I did enjoy talking to him when he suggested what I am currently using. I love my wheels set!!
