update on ole blue trike
yellowbeard
put custom chrome pipe and breather, and a few pics of my chain guard that I fabbed up. Joe
chain guard pics. in other thread ( 10 tooth on front 54 on back
New pics. Below
Unless there's a baffle we can't see that must be one loud puppy with that pipe right out of the exhaust port.
How does it run? I had a lawn de-thatcher that was my father-in-laws with the syphon type carb. We never could get it to run. Rebuilt the carb and checked everything Briggs suggested but it would never pick up fuel from the tank. It ended up in the scrap metal and he bought a new machine. Briggs said if the compression was too low there wasn't enough crankcase vacuum to operate the fuel pump diaphram. Worn rings?
I'd like to see the whole trike. Links to the build would help.
tom
Looks really good but I think that the neighbours will taking up a collection to but you a muffler.
The air cleaner looks great as well.
Steve.
You'll have to change the file name of your photo to use it again.
Bring the photo up in whatever program you use to resize and 'save as' then type in a new file name. You'll have to do that everytime you plan to repost that photo. Sorry, it's just the nature of the forum software.
new update
here's some finished pics. may need disk brakes, and hook up the kill switch. Took a little ride down the driveway. Joe
here's the pics. of the finished trike. May have to add disk brakes. Took it for a little ride down the driveway. Joe
Got a chance to ride it yesterday. It will putt down the road at about half throttle around 20-25 mph. real comfortable ride. Happy with my build. Ready to build something else now.cvlt1
is your trike just using a centrif clutch with a 10tooth and no internal gearing at the engine? so a 5.40 final? how many horse is that?
10 tooth front and 54 on rear. Centif. clutch going straight to the axel. I pedal alittle to help the clutch out. But no need to, it will take off on it's own power. It has a 5 hp. B&S on it.
