I picked up this 17" Puch moped wheel with the intent of using the hub/drum brake for my build. It has a 44t ring on the engine side, and a French made (Sachs?) freewheel on the bicycle side. I believe it is from a late 70's vintage moped. Good points- this wheel uses .105 (#12) spokes, so the holes in the flange should be a perfect match for the spokes in the BikeWorldUSA Heavy Duty rear wheel that I have. So hopefully I will not have to buy new spokes. Also, this hub already has the drum brake built in, with plenty of spares to be had. Final good point, I won't have to deal with a rag joint or hub adapter since this hub already has gearing on both sides.
Now the not so good- this hub is WIDE. I anticipate I will have to spread (cold-set) the rear dropouts around .75" on both sides.
Anyone have any experience using these moped hubs and can give me advice? Like maybe remove some shims and make the whole assy narrower?
For reference, I got this for $42 shipped on ebay.
