Cafe Racer
fx-2
Wanted to build one for some time now. Tank and seat will be the hard part . Here the start . Dan
that bike looks like a good platform for a cafe style build. you could build a seatstay out of wood and find a way to attach a seat to it. or just stick a banana seat on it. for the tank, find one you think looks good that will fit on the frame. I would also put some fat tires on there, but thats your call. either way, go with what you like. good luck.
Yes that a Puch head . This should be a little go fast street bike . It a small frame , I think a 18" . Have most of the parts now just need time .
Quick up date , got a little more done today . Worked on the frame for the seat and some on the cylinder .
Worked on it a little today . Made some drop out for the rear wheel and brazed them in . Started on the buck for the seat tail assemble . Pickup the forks I'm going to use . Dan
DAN and I opened the box's from the mail and here's what we got( get a napkin your gonna need it)
OK just a few more, and "let the fabbin begin"
Hay man I'm used to doing just that!You never know .It was good to see you on sat ,any funny storys from the1%ers?
Just a little . Got the case tig up and match to cylinder ports . Pressed apart crank an installed a moped con rod to match piston pin , Mocked up the motor to check the thickness of the spacer . Need to build spacer now , I just need to get some time on a milling machine now . Should have gotten more done but I screw up my right hand was off work for 4 weeks . Will post some pictures soon.
Up date on build . Just a few new parts .
careful, remember what happened when the french got that close to china err vietnam? KABOOM!!! walk on ricepaper grasshopper san. i see you speak 2 stroke...nice. dennis
Here's an update.We just got Frankin Crank back from Mr. Rust, it looks kind of scary but he daid it would work, he stroked it 4mm and replced the lower crank rod with the one that came in the kit and ballanced the whole thing.We also finished the wheelset their pretty heavy but they seem bullet proof,we may be rethinking our frame choice any way here's some pics Later Bob
