Thanks
I will go get them and have fun riding it today.Oh whats gap suppose be on the ngk b6hs or are they already pre gaped.
Don't ever trust the pre gap on a plug. Once I buy a plug, I over gap it and then close the gap to what I need. I've read years ago (new plugs made today may not have this problem) that without doing this the gap can be change in the heating process. Old school, I still do today.
From the NGK site...
Do I need to Gap my plugs?
Maybe, but likely not. Many plugs are pre-gapped for their most popular applications, however, the gap can be altered if the plug is dropped or mishandled in packing/shipping. Therefore even if the plugs are supposedly preset for your motor, it is always wise to check the gap on each plug prior to installing. For information on how to adjust the gap see Proper Gapping.
Proper Gapping
In most cases the factory set gap should conform to your vehicle specifications. However if it is necessary to widen the gap, do so with a tool that only pulls back on the ground electrode without touching the center electrode or the porcelain. To close the gap on a plug, gently tap the plug, electrode first on a hard surface.
Here is a good site about spark plugs.
http://www.dudeworld.com.au/ARTIPLUGS.HTML
