Russell
Super Nice. How Do You Like The Gear`s/multi Speed`s, After Having The One Speed Ratio?? Your Spoiled Now, Hard To Go Back!!
I Tried To Find Pipe And Bearings That Fit And Would Not Need Lath Work! Had No Luck. If You Don`t Mind, How Did You "Git`r Done" ?? Are You Using 5/8" Shaft? Do You Have A Bearing Number And The Tube Spec`s?
Thanks For Sharing. .Ron .![]()
I'm trying to figure this out. You have the freewheel on the jackshaft? I don't see it on the crank. Can you still pedal backwards while moving?
(edit) Oh I see it now. The freewheel sprocket on the crank side does the freewheeling.
Now how did the smaller drive sprocket get in there?
And you got roller bearings spinning the shaft?
(edit) Just saw first pic.
This is real slick! Makes me wish I had a welder.
And it's GREAT that you don't need a freewheel crank.
BRAVO!
