glacknoid
Hey everyone. JUst wanted to share my experience with the stage 3 grubee lubrication process. I put super lube synthetic grease on the gears and added about 65 cc's of amsoil synthetic super shifter trannsmision fluid and it made my clutch slip alot. Very slow acceloration. After cleaning everyhing off and reapplying the super lube synthetic grease to the gears alone, I had much better results. I'm not saying you can't add any fluid but I would go more towards 50 cc's and be ready to possibly drain,clean and reapply grease. The oil actually mixed with the grease while it heated up and made it all liquidy. I don't know if there is a product out there that does a good job lubrricateing the gears and aiding in the cooling process ,if that's even necesary, and yet doesnt inhibit clutch performance over extended use, but if there is anyone who has a tried and true product.
The instructions to put 50 to 80 cc's of 10w gear lube was not specific and tracking down a 10wt gear lube was not easy in small quantities. Amsoil lead my to beleive this would be good for a wet/dry clutch application. Maybe it's that it mixed with the superlube and made the combined solution too slippery and liquidy. Possibly the amsoil alone would not have had that effect, don't know but I realy don't want to experiment over and over again. So like I said and tried and true other than just the super lube would be nice to know.
Thanks
chris
Thanks
chris
