I know this a common post, drive chain rubbing frame just need some ideas to try...
Rusty_Nail
It wasn't an issue when I first built the bike. I recently had to remove the engine to fix a problem. But since I put the engine back on the frame this has been a constant issue with the drive chain rubbing the frame, especially when the master link passes by it. One tip I heard was to use a spacer on the rear wheel to help it clear. Just wanted to see if I could get some other ideas to try if the spacer doesn't work. It's on a cruiser frame. Any help is appreciated.
The first thing you need to check is to make sure that your back hub adapter is properly mounted if it is a rag joint there's not much you can do but if it's a clamp on you can move it back and forth in and out just a little bit.
This is a problem that I had to address. So what I did is I spread the back triangle and it helps. But be careful not to do it too much because you'll compromise the area that you have for the rim to fit.
What I did is I took a piece of all thread and put two nuts on the inside of the dropouts and then one on outside of either side and crank it out. You probably have to go further than what you want to stretch because the frame is going to come back a little bit and only do a little bit at a time or you will very quickly run out of room for your rim.
When you're done check the alignment of your dropouts where your back wheel bolts on make sure those are straight because if they're not it's going to pull back in when you tighten down on it
I also added two bolts to the inside of the axle rod so is to help keep it spread out.
That's why I have 3 tensioners on my bike. The back dropout is so narrow...
I've got the case mounted one with the spring on it that's what keeps all the slack out of it and the other two are just for guides to help keep it away from the frame..(remember I'm riding the tandem that I turned into a stretch and it's got like a full chain and a half on it so I get some wicked chain slap if I don't have something there as a guide. )
Mine was rubbing so bad that I had to actually cut a piece of bicycle frame and clasp it around the area with the chain was because it really was doing a number on it now it just bounces off the metal sheath.
Thank you guys for all the helpful advice, I appreciate your time. I just got time to work on it and fixed the issue. Thanks again everyone for your input.
Ok guys, finally got a pic of it. Just added two washers between the frame and nut that holds the coaster brake arm on. Now chain doesn't rub at all. Worked perfect!
