Can be a spring on the throttle cable of a saw carbPut a spring from a retractable pen in the line to hold it open. If y need a longer one ace hardware has them. View attachment 112631View attachment 112632
If you had a spring in it you wouldn't have to dangleHow about a full view of your fuel line and how it's hooked up to the other end.
Is it because your fuel line is stiff and the lower hose bend to get it to where it needs to go kinks the top line?
If so just use Motion Pro gray Tygon fuel line it's really flexible
Should use Tygon fuel line anyways
Have you built a M/B yet or are you still doing research?If you had a spring in it you wouldn't have to dangleit around the choke lever
It might be just the lighting but your pipe thread tape looks white,Put a spring from a retractable pen in the line to hold it open. If y need a longer one ace hardware has them. View attachment 112631View attachment 112632
Actually it’s the new nitro proof super pipe thread seal from China, don’t you know anything?It might be just the lighting but your pipe thread tape looks white,
Yellow tape is for gas
Not since '14 the research continues... Availability plus there's a lot of new and old stuff to get... It's taking 2 years just for the clutch parts to become available... Looking back at all the business that's closing... I'm really glad I waited... Plus there's a value to knowing what's out there... Posting the current price and availability is my gift to the forum... Try putting together parts for 10 different builds at the same time... 2 and 4 stroke...Have you built a M/B yet or are you still doing research?
He knows nothingActually it’s the new nitro proof super pipe thread seal from China, don’t you know anything?
Not all built at the same time but over years one at a time... There's already stuff I can't get anymore...Try putting together parts for 10 different builds at the same time... 2 and 4 stroke...
This will never work as you jump from on to the other and be lucky if you get a couple done..............Curt
Good Lord was a carpenter and should appreciate my years in the making projectsGood lord says you must not need it...........Curt
