212cc Predator motor mounts for aluminum Felt
Tony01
1,744
1,751
sf bay area
I have a short valve cover on my engine, I plan on drilling and threading a whole for a one way valve, but I was waiting till I got the engine on the frame before doing that, got the stuff to do it though
The breather assembly is a lot more than a one way valve. It also filters the oil from the pulse charge and allows it to drain back to the motor.
Collin Parks
11
7
3
27
True but I think I'm going to fit a different motor to it instead so maybe I'll put the old cover back on, if I can find it that is, I have a 79cc predator clone, I think not sure exactly what it is, but I'm going to see if I can fit that, if not I have a small 49cc motor and mount I know will fit on the frame
Collin Parks
11
7
3
27
Did you ever figure out if the 212 will fit in the frame?
it will only fit if it's mounted vertically, and id have to make a mount like the one you made I think as the space between the engine and the seat post tube is very small, but I don't have the means to make a mount like yours at this time so ill try a few smaller engines in the meantime to get it working so i can ride it
