Green Goblin
Started my first build in June 2022. Looking to share what I've learned and learn what others have to share.
This place is a grave yard used to be thousands everybody is on different platforms now .Started my first build in June 2022. Looking to share what I've learned and learn what others have to share.
Have you ever considered a shifter build?This place is a grave yard used to be thousands everybody is on different platforms now .
What have learned about motorized bicycles since you got it . I like talking bikes . I rode through Houston a few times 22 lanes of traffic wow . I just purchased a 50cc yesterday. It doesn't come in till nov 4th.
My first lessons before I even started the engine: Take the engine apart and examine, inspect, adjust, grease and tighten everything. Had a crank case gasket leak on a brand new engine and removed the damaged paper gasket and used Permatex MotoSeal Ultimate Grey RTV Gasket Maker instead of buying a new gasket. It is specifically made for two stroke crankcase halves. Make sure the magneto is oriented correctly so the timing is right. Clean the gas tank before first use and use a quality fuel filter. The stock fuel filter came loose on the inside and failed; causing debris from the uncleaned tank to clog the needle valve in my carb and flood the engine. Watched a s#!t ton of YouTube videos such as: Remove the fenders that came with the bike THEY CAN KILL YOU!This place is a grave yard used to be thousands everybody is on different platforms now .
Sounds like all well earned advice thank you. You must have gotten it running pretty good then. That's greatMy first lessons before I even started the engine: Take the engine apart and examine, inspect, adjust, grease and tighten everything. Had a crank case gasket leak on a brand new engine and removed the damaged paper gasket and used Permatex MotoSeal Ultimate Grey RTV Gasket Maker instead of buying a new gasket. It is specifically made for two stroke crankcase halves. Make sure the magneto is oriented correctly so the timing is right. Clean the gas tank before first use and use a quality fuel filter. The stock fuel filter came loose on the inside and failed; causing debris from the uncleaned tank to clog the needle valve in my carb and flood the engine. Watched a s#!t ton of YouTube videos such as: Remove the fenders that came with the bike THEY CAN KILL YOU!So can the chain tensioner that comes in the kit unless its modified so it wont tip into the spokes. I just replaced it with a BBR Tuning Arch Chain Idler Tensioner. Anyway, these are some of the beginner lessons I learned.
Maybe what have you got in mind ?Have you ever considered a shifter build?
I see your bike in your profile sweet bike My first lessons before I even started the engine: Take the engine apart and examine, inspect, adjust, grease and tighten everything. Had a crank case gasket leak on a brand new engine and removed the damaged paper gasket and used Permatex MotoSeal Ultimate Grey RTV Gasket Maker instead of buying a new gasket. It is specifically made for two stroke crankcase halves. Make sure the magneto is oriented correctly so the timing is right. Clean the gas tank before first use and use a quality fuel filter. The stock fuel filter came loose on the inside and failed; causing debris from the uncleaned tank to clog the needle valve in my carb and flood the engine. Watched a s#!t ton of YouTube videos such as: Remove the fenders that came with the bike THEY CAN KILL YOU!So can the chain tensioner that comes in the kit unless its modified so it wont tip into the spokes. I just replaced it with a BBR Tuning Arch Chain Idler Tensioner. Anyway, these are some of the beginner lessons I learned.
Here's my bike.Maybe what have you got in mind ?
What kind of build are we talking about? are you reading my mind that 5g does work![]()
Very cool how does she ride ?
Triple chainring shifter, 33cc, I live in the mountians and weigh 230 lbs. Set up is on it's second bike. Been riding for 12 years. Have conversations almost every place I stop.Very cool how does she ride ?
This is the bike i used to go across America.
