Connection rod needle bearing sizes?
Testname111
OK I found a good bearing for the piston top being 10X14X15 brass bearing from Amazon
Looking for silicon nitrite/ceramic
Buttt is this the correct size for the bottom connection rod bearing?
16x22x12
As this the only bearing I could find on Amazon, if anyone could point me to a more professional/long service life baring? Maby silicon nitrite/ceramic bearings to replace the crap ones that came on the crank?
16x22x12
Not brass and the bottom bearing needs to be pressed in with a fixture to keep everything aligned or your going to be out of true.. wobling... VXB has your bearing... it's common KT101415
