I've had one b4.I know there so,so.Those don't work well. You should have bought a Mr. Tuffy Tire Liner.
I'm not sure. I know they cause drag.Was it a Mr. Tuffy tire liner that you had or some other brand like slime? There’s a difference. Those slime tire liners stink bad.
What happened to me was rode trash. 1st was wire like a pAper clip. 2md was a name bamboo.If you have double walled rims sometimes small metal shards can be in the hollow section of the rim. I discovered this when I kept getting flats. It'd always be on the inner part of the circle of the tube but in different locations. After fishing out all the shards the flats went away.
Often people don't understand the legal far right requirements for cyclist. A cyclist is only required to ride to the far right if the lane is wide enough for lane sharing. This isn't the same thing as lane splitting where cyclist are allowed to ride between vehicles stopped at traffic lights when certain conditions exist. Lane sharing is legal throughout the the USA; however, lane splitting is only legal in a few states.What happened to me was rode trash. 1st was wire like a pAper clip. 2md was a name bamboo.
Both destroyed the inner tubes.
I tried patching both for 2hrs each with no luck. Had to replace both tubes.
I ain't dealing with that anymore!
I explained all of this to let you know if a lane isn't wide enough for lane sharing then you have the right to use the whole lane. The safest place for you is in the center of the lane. This way you'll avoid road debris.
Also eyeballing a 3L gas tank...lolI don't like riding in the road but it's quickest. Then there's also sand Spurs.
I may just get a liner for the front wheel.
I'm fixing this problem...
Yeah I don't do Slime cause that's all it is is SLIME...I try and steer clear of slime. It is a monkey mess if you get a flat and then try and patch your tube. You can't patch a flat with slime in it.
Eliminate the leaky stud mounts and go with the tab mounted 4L...Im
Last puncture was a 1/4" hole. Only FIX was a new TUBE....For you anti-slimers- If you go with the Goodyears and slime, you won't have to change/fix a flat unless you run over a 1/4" fender bolt.
Don't ask me how I know.
