Pjones
Hi everyone,
I'm looking to convert my electric Razor Drifter Kart over to a gas kart with a weed eater engine
I have a Stihl FS38 (im pretty sure thats it... yeah, thats it) that I can use for the project and I'm wondering about everyones advice on the project.
I'm not convinced the engine will be powerful enough. it is 27.something CC engine which produces 0.65kw output according to the specs (for those who are mathematically inclined, maybe you can tell me what that means to this project)
It has a square drive output and I'm stuck as to how i can attach a gear to it. The drive comes off the clutch bell and I thought I could possibly tap the drive hole and bolt a sprocket to it.... i'm sure there is a better way. I'm open to suggestions.
now for the good stuff... pictures of my junk!
Yep, she'll fit all right!
The beast and its name
a shot of the goods under her skirt
Sometimes you just want to see from different angles... I don't judge
This is such a bad photo... I thought i had a photo of the drive output but i failed to take one before swiping the motor over to a Kombi shaft to see if it could power the attachments (it cant)
that's the drive shaft on the original whipper snipper head, or whatever you want to call it.
I haven't determined what the gear ratio is on the kart right now but figure keeping a similar ratio will either be a good thing... or a bad thing. This was based off physics size so a percentage of error may be present.
I guess I 'll need to figure out how many KW this motor is. Google will be my friend here eventually, but from looking at the diameter of the motor I’m thinking it’s going to be torque’e
The motor in it now is a 24V this thing... it spins i think... yeah, it defiantly spins!
Anyway, my time on the computer is up now. I'm curious to hear what you have to say, and if you think this project will work out ok.
Cheers!
Cheers!
