I always do my best to go without any type of chain Tensioner / Guide. I have used on 4 bikes over several years never a problem, and yes it is the TurboBuick model. We have since replaced the Mapbike cut roller with this 10 T sprocket.https://www.amazon.com/Oregon-34-81...coding=UTF8&psc=1&refRID=PDXF4A4PGPVFP9D5DEFK
https://motorbicycling.com/media/1s...s-too-does-make-for-a-very-happy-chain.10746/ The idea is to guide your chain while removing excessive slack. The turboBuick tensioner should be modded with a stiff spring which will NOT allow bounce during de-acceleration.
Several useful tips can be found concerning Happy chains in my "Happy Chains Album. Good Luck to you!
I like spring tensioners, build some, buy some typically they need some fitting and fiddling. I like to run them on both pedal and motor side and I also like a stiff compression and rebound. Multi speed pedal bikes use them quite successfully, work as well on motorized bikes and eliminates all the messing around adjusting two chains that wear and stretch at very different rates. Set the chain line straight and the tensioner runs smoother and quieter than with a fixed idler or just chains alone. If you are running a chain close to the tire and/or close to the chain stay a well placed tensioner of some type helps keep the chain from rubbing.I always do my best to go without any type of chain Tensioner / Guide. I have used on 4 bikes over several years never a problem, and yes it is the TurboBuick model. We have since replaced the Mapbike cut roller with this 10 T sprocket.https://www.amazon.com/Oregon-34-81...coding=UTF8&psc=1&refRID=PDXF4A4PGPVFP9D5DEFK
Allen 72 on June 23, at least we know our Dad's remembered to give our Mom's something for Christmas!Hey Rick! are you 72 yet?
I'll be 59 on the 24th.
The same to you my friend!Thanks Rick, All throughout my life my best friends mentors have always been 10 or 15 years older than myself. Even today! Most are in good health except for the x smokers. None the less I wish you a happy healthy B-day my new friend.
I came around in 1946 and in 1975 I quit counting since the time went so fast!The same to you my friend!
If a fella runs 415 chain he needs a chain tensioner on the chain since it has a habit of stretching!Thanks Allen some of the best bike builds ever didn't use chain adjusters, some used well thought out motor mounts that allowed motor drive chain adjustment & axle drop plates that were a bit oversized in axle slot length for fine tuning the chains with axle adjusters. As I said fine builds. I hope my preferences, which I've stated, don't sound like I think everyone should follow my way of doing things. I don't. I personally am storing up a lot of good ideas from other builders, but most of these won't ever show up on any of my bikes, though they could because they are genius for certain builds. Three weeks and I'll turn 72 and each day I'm blessed with I hope to learn something new, interesting and useful. The posts on this forum is a great help in that quest.
Thanks to all, Rick C.
That's my goal lol. Just to go for it and if I make a few mistakes, I'll definitely learn from them. The rag joint tensioner is the one I sent back, I couldn't get it to work right now mater what I did. "Junk" may have been a strong word. I'm sure someone must have had more luck with it or they wouldn't make them. My problem, aside from the chain compleatly shredding it, was bouncing. No matter how tight I set the spring it was just bouncing back and forth. Sounds exactly like you were talking about with tight spots and loose spots being the cause. Good eye seeing the valve stem like that, I didn't. The photo is from last year, and it most definitely DID cause a flat. As always, thank you Indian for your words of wisdom, it is most appreciated.Glad you got the chain tensioner sorted out Jake. Like most things on these one of a kind bikes off the shelf parts often require some or a lot of modification to work on different bikes. The term kit bike is a complete joke and those who try to use them as such are often quite disappointed. Those that modify make a lot of mistakes till they build several of these or fight one till it's right. A decade of building moto bikes has taught me a lot and one lesson is let the newbies make their mistakes and learn the hard way. A lot of experienced post answers and show photos of what works well, but most pay no attention to advise given. I use 415 chain and have never broken or thrown a chain in ten years of riding and I credit that to running perfectly straight chain lines and using well designed spring tensioners that are properly installed. If chains are breaking it's the builders fault not the parts.
I noticed that you are running a rag joint sprocket & these things tend to be very difficult to run concentric (along with other properties) this poor centering causes the chain to run tight in spots and loose in others on each revolution of the wheel & this can break a chain. Using a three bolt sprocket mounted on a good hub adapter is something to consider. Rag joints work ok when properly installed, which few are.
Jake the valve stem should be perfectly vertical, that's a flat waiting to happen. Happy building!
Rick C.
The only thing I had trouble with it was spacing the gear sprocket and I really didn't like using them since you do getI went with a spring tensioner day one, when I saw the one that came with the motor, and how it installed I knew it was going to fall into the wheel.
I had that happen a few year ago and use a cord to pull on the tensioner to get back home. That tensioner was a spring tensionerMy spring tensioner broke today well the bolt holding the arm to the bracket came out luckily I was only a couple blocks from the house.
