My bike is 4 stroking like crazy. I have tried almost everything to fix it. Changed plug gap, changed oil mixture, changed the jet and needle to the leanest possible (60 jet is the smallest that I have), while it worked for a while it started doing it again (probably because it was colder that night than now), I changed the timing with an offset woodruff key, I switched CDIs, but nothing. One thing that stands out to me is that I got it working pretty well and then it started 4 stroking a lot when I tightened down the air filter tighter than before I might loosen it a little or find a less restrictive one but I ran without a filter and it still 4 stroked. Here is the spark plug after a few WOT pulls with 4 stroking. It looks rich to me and the engine stays really cold even during hard pulls. It usually stays between 120-130 degrees celsius and after hard pulls 140-150. Highest I've ever seen was 160 but it took a lot of WOT pulls. I think either the head gasket or the exhaust gasket is leaking as well. I wonder if that could reduce effective exhaust scavenging or something. I did some pulls with WOT and the spark plug was very dark at the ceramic and the band was kinda grayish. There is also one very noticeable (but hard to see with the angle of the picture) very dark spot on the ceramic portion next to where the spark occurs. Any help would be greatly appreciated. Thanks.
