This has been so much fun. I have 3 bikes I'm working at as I have time and the longer I'm at it the more I keep changing my projects around. I decided to go 4 stroke gas power on the older steel frame Miami Trike I found. I like the 24 inch wheeIs but I don't like the light weight frame. It looks like it will need some gussets and bracing ( hopefully in good locations). I need a 4 stroke so I can get off the bike and leave it running. I have a harbor freight 212 and a 79cc. and a china girl. I would like to go with the lighter engine but I'm not married to any particular way. Speed isn't the factor here, being able to take off without pedaling is a major factor for this trike. It will spend it's life in parking lots and office centers
O-K Here's what I have. I've measured several times with a digital caliper that checks out against my inherited old mitotoyo. The axle I would like to put a drive sprocket on and maybe a disc brake, measures out at 14.85mm or the decimal .584. I'm not seeing anything that matches what I think I need ??
I've tried a couple 1 1/2 inch hub adapters, but on the 24 inch wheels there isn't enough room for the bolts where the spokes meet the wheel hub. If I have to, I will try a rag joint. I also have a repro whizzer sheave for a future project i could use also.
I would appreciate any ideas
Thanks
Zing
Thanks
Zing
. That being said I can't wait to finish and take it for a test ride.
