Helpline
Bkent1083
Hey guys I’m new to the motorized bike scene and have a couple questions , first off is there s phone number we can call for actual assistance? Talking to a person will really help! I had the bike running the other day , now it’s still new and in the break in period . I had to take the small sprocket on the clutch case off and s little metal piece fell out, and left like a notch? Any one know what thet is or if it won’t start because of it? Also on the carburetor where the throttle cable goes in that little slide, I noticed that the little guide on the carburetor had fallen off as well.. again with this affect the motor from starting ? It’s a 2 stroke 66cc. The bike will start but it’s almost as tho it won’t get gas
There is a keyway under the drive gear, make sure the key is in place. The needle goes through the slide with a flat disc with a notch cut in it on top, the spring goes between the cap and disc with the cable through it all. Below is a link to a carb repair thread with pictures.
https://motorbicycling.com/threads/motorized-bicycle-carburetor-install-and-rebuild.302/
Thank you ! I realized that the woodruff key fell out as well, I’m replacing it tomorrow hopefully thet was the only problem, thank you for your help tho
