Metalhead6969
Will a high hole piston and cylinder work on a low hole crank and rod ?
Cuz I ordered the wrong piston and cylinder !!!!!
You can't like shave The skirt down?nope, hopefully you could return them
Can you get the matching rod or do you have to get the matching Crank as well?The cylinder should still work, it's only the piston that you need
Cool, then I can use my old piston witch is kinda scored.Can you get the matching rod or do you have to get the matching Crank as well?
Do a double head gasket (if it's close)I'll go ahead and put it together and see if it clears top with plug in it, maybe double head,base gasket or shorter plug.
Thanks again guys.
And I'm looking for members from Sacramento CA.
