Need Trike Mounting Pics
OSCAR383
Anyone Who Has Done A Trike Can You Help Me Out? I Need Some Ideas On How To Mount Sprocket To Rear Axle Of Trike Kit. Trike Rearend Is From Us Cycles. Any Help Would Greatly Be Appreciated
Oscar,
Don't know if these will help or not. This is an install on a weird little trike but the rear axle and sprockets should be about the same for all of them.
Good luck and keep us informed because I have a trike too that's begging for an engine.
thanks everyone for the help and aussie ive been following your build . you and your welder are just sick and your photo shop'd sticker rotfl
Dont stop. Mount to the middle to the friction brake disk
This is the easiest way to do it.remove the sprocket from the bike. Take it and the sprocket you want to use to a machine shop. Tell them that you want 4 holes to line the 2 sprockets up. N,S,E,W. Use 4 bolts and nuts and washers to get the clearance you need. Yery inexpensive.
Dont need a machine shop
