jeff henson
Why would my engine bog down when I turn the throttle, but when I let it go, the motor revs really high, like the throttle is stuck?
Got it running like a scalded dog. Now the throttle cable broke out of the throttle handle. Cheap plastic that it hooks into inside the handle. Looking for a fix.Hi Jeff, if you can give us a little more info someone will help. Is this a new build? If so check the throttle cable, the barrel has to close all the way. Check for air leaks at the intake, this will cause it to rev without throttle. Good luck.
Thanx. I'll go mess with it later. Been broke down out in the dessert for 3 hours. Just got back.glad i had black tape. Lol!!!get new twist grip or drill 2 tiny holes and tie cable down with safety wire
Not sure what safety wire is. ???Thanx. I'll go mess with it later. Been broke down out in the dessert for 3 hours. Just got back.glad i had black tape. Lol!!!
Thanx
