Alexander Owens
The nut that runs to the clutch cable on top of the casing with the three screws?
			Should I use a Philips or a flat on the impact driver because it started to strip its the only bolt that you see go through to the other sideThe nut that runs to the clutch cable on top of the casing with the three screws?
Top right in the triangle.Should I use a Philips or a flat on the impact driver because it started to strip its the only bolt that you see go through to the other side
And that bolt on the top seems loose when I flex my clutch cable it reacts is it supposed to be torqued to any degree or does it matter because once I take off I need to know when I put it back on its seems to be connected on a spring with a lengthwise peg whrn I pull the clutch it pulls right if your behind the bikeTop right in the triangle.
And that bolt on the top seems loose when I flex my clutch cable it reacts is it supposed to be torqued to any degree or does it matter because once I take off I need to know when I put it back on its seems to be connected on a spring with a lengthwise peg when I pull the clutch it pulls right if your behind the bike
I tried to get it it off the one that goes all the way through and it started to strip it what size should I use a 3 or a flathead?first step is to get the three bolts off that hold the drive cover - the bolt at the upper right goes through the case and sticks out the back - if there is a nut on it back there take it off first - now get all three bolts off - a hand impact driver will do it easily, but sometimes putting just a screwdriver in there and hitting it with a hammer to loosen the bolt will work
Hey I got the chain fixed it was triangle jammed like I thought I guess it's to loose I had someone helping and he took the cover off the magneto and when it was put back together will not start for anything so I went back and took the magnet off and see the woodruff key is gone cant find it anywhere I'm assuming the bike will not start w/o it I was reading another post that has to do with my motor it has the do not ride on the road according to the epa sticker on the mag cover I'm trying to figure out what size the key I should buy
Im not sure if you've seen my questions but I did get the back tire off and the chain fixed it was triangle jammed in the top of the case I'm going to just replace the cheap Chinese bolts because they are about stripped but as were diagnosing it the guy working with me took the mag cover off then took the magnet off and put it back on I had no idea of the woodruff key that was holding it at the 1 o clock position so now after trying to crank the bike that ran beautifully for hours i finally yook it apart and realized this key was gone and im trying to find out the exact size or if they are universal for the half crescent key or if i should just drimmel my ownmotor has to be so solid that a strong man cannot hold the frame and top of motor and make it move at all - if it ever moves, it will roll to the left snapping the chain and ripping motor mounts out of the motor ruining both
read a lot & look at pics of finished bikes here
He was talking about the carburetor being dirty it took me a while seeming how there is so little about the most important key of the 4 everyone seems more worried about the one in the crankcase and when I try to shop for one same problem so I'm confused it's like the magneto one must be impossible to lose because I rarely find anyone talking about it it's getting extremely frustratingIm not sure if you've seen my questions but I did get the back tire off and the chain fixed it was triangle jammed in the top of the case I'm going to just replace the cheap Chinese bolts because they are about stripped but as were diagnosing it the guy working with me took the mag cover off then took the magnet off and put it back on I had no idea of the woodruff key that was holding it at the 1 o clock position so now after trying to crank the bike that ran beautifully for hours i finally yook it apart and realized this key was gone and im trying to find out the exact size or if they are universal for the half crescent key or if i should just drimmel my own
When youI was referring to this "so I tried bolting it on just by the back but that doesn't seem right" - for your woodruff key, take one out from under the drive sprocket to take to store as that is same size as one under rotor - hard to lose one under rotor because it always sticks to back of magnet
When you[/QUOTE
When you say drive sprocket do you mean where the chain was jammed up in the case or the other side with the 2 cogs one big one small with the star bolt it's under there?
And will it definitely not run because of that key I'm thinking so and how the **** did it disappear when it sticks to thst magnet
