Talked to Jim at sickbikeparts about his expansion pipe and I may be going that way as I'm realizing what you are saying, but I'm running a 20:1 synthetic oil fuel right now as part of the '3 tanks' break in and that may be much of my problem acc'd to posts here and sickbikeparts. He starts at 25:1 for break in and goes up to 40 to 50:1, so I need to get that stabilized and see what happens there, then I might be able to make headway on other potential issues that still exist.
Give me a quick primer on squish gap. Have done alot of work on this thing and have no problem adjusting this. Just need to fully understand the concepts involved. I had a 'race head' from bikeberry on here before this one that definitely made more power, but had very little cooling capapbility and for long uphill runs at lower speeds because of hauling a heavy trailer, I needed all the cooling I could get and the Fred Head seems to be the best at that. But definitely lost power with it because of loss of compression.
Had a boost bootle from bikeberry on here and it was nothing but trouble with vacuum leaks, etc. There's even youtube videos showing where the problems are from a long time ago. I figured they must have fixed these known vacuum leaks...well, they didn't. I had the same problems and had to return the thing.
The Squish gap is the gap between the head and the piston when it's at top dead center. When the piston gets to the top the ignition occurs. Making the squish gap smaller will increase compression giving you more power along the entire throttle range. However, if you make it too small it will restrict the volume of fuel to the point where you will lose power. For these little engines a squish gap of between .025" to .035" is optimum.
The first thing to do is measure your squish gap. First your going to need some soft leaded rosin or acid core solder.
.050" Rosin Core Solder
.062" Rosin Core Solder
.093" Rosin Core Solder = NAPA Auto Parts PN # 777-1862
.125" Acid Core Solder = NAPA Auto Parts PN # 777-1857
You may have the right solder laying around, or at your local hardware store.
Basically you cut two small strips of solder about 1" long.
Give them a slight bend so they match the contour of the top of your piston.
Prep the engine so that the head is removed, the cylinder is installed, with the piston installed on the rod and the head gasket you intend to use in place.
Now:
Use some heavy grease and place the two bent 1" pieces of solder on the top of the piston.
Placement is important!
They must be directly in-line with the piston wrist pin, and they must sit on opposite sides of the piston. Place your two pieces directly in-line with the piston wrist pin so that one end of the solder piece goes right to the edge of the cylinder.
Once you have your solder in place, carefully rotate the crankshaft so that the piston is just below top dead center.
Assemble the head onto the engine without the spark plug.
Torque the head to the torque value you use (I use 15 foot Lbs.).
Make sure the clutch is engaged (clutch handle released) and grab the back wheel. Now rotate the crankshaft through top dead center, compressing the solder. It will be kinda hard to compress the soft solder, just pull the wheel up to run it through once.
Remove the head, measure the thickness of the compressed solder at its smallest point (usually the edge closest to the edge of the cylinder).
This measurement is the SQUISH GAP.
If the gap is bigger than 0.060" you might as well not even have a squish band in the head, and you are not going to get the MAIN benefit of the Fred Head, the optimized squish band. However, the Fred head will still provide you with superior cooling over a stock head. Those big fins really help keep temps down.
If after you have your measurement you decide you need to deck the cylinder, but have no idea how to go about doing it, I will walk you through a super low budget method I have used. All you need is a reasonably flat surface like a piece of glass about 1' square or larger, and some varying grit sandpaper.
