On an old thread, another member installed high-performance pocket bike engines on his ride. He had problems with "blowby", compression leaks between the cylinder and the engine block. To remedy this, he installed extra long 90mm cylinder bolts and screwed them deeper into the bolt holes. Along with thread locker, he even installed M5 nuts re-threaded to bolt onto the M6 threads behind the flywheel (There's no room for any sized nut behind the clutch, because of the interfering crank bolt heads).
I decided to do the solution one better and replace the head bolts on my engines with M6 studs, like these:
https://www.amazon.com/uxcell-100mm-...words=m6+100mm
While removing the 84mm head bolts, I noticed that two of them seemed slightly bent and rubbed the cylinder fins. So, before installing the studs, I took a few minutes to file down the top fins.
Problem solved, and the 100mm studs slipped in easily. No bending or rubbing the fins.
In fact, I double-nutted them and screwed the studs 10mm deeper past the bolt holes in the block (On the flywheel side, I managed to screw the studs in more than 10mm).
View attachment 95061 View attachment 95062
View attachment 95063 View attachment 95064
I did this for practice on my spare engine, not the high-performance one in my twin-engine project.
On my unmodified pocket bike engine, I'll replace the 19mm cylinder bolts with 40mm studs.
