A month ago I finally purchased my first kit! It was a Bike Berry 49cc lock and load friction drive! This kit lasted four hours before I ripped the clutch drum right off and wasted the clutch. How? I was told by bikeberry this was my fault and it was because of cold starts. I explained to them that I could not of cold started it because it needed to be peddled before It would even move. After an email message from them stating my clutch drum was out of stock and it would be three weeks before the new one shipped. I was upset and their customer service treated it as a joke they would not issue me a refund or supply me with the parts to fix it for three weeks. I was furious and felt as though I have been ripped off. I wasn't going to wait three weeks for the part not to mention the drive roller is mis aligned and the drive roller creates tons of drag. I decided to buy a staton kit and mount my FS engine on it. I installed the kit with the heavy duty clutch and the kit looked solid compared to the bikeberry kit and could not have been happier. Any ways it lasted for about 2 days the threads ripped right out of the clutch drum. I spoke with Dave and he shaved some off the clutch drum because he thought the clutch may have been in contact with the face of the drum. I waited for the drum to arrive and he instructed me to use red loctite. I received the parts a few days later put it all back together cured the loctite for 24 hours and went for a ride the threads stripped out again. I talked to Dave he said that I have to release the clutch while going down the hills and coast. I've tried this I have to slow down to almost 5 mph to get the clutch to release it takes a good 30 seconds or so. Then when I get done with the coast and the bike slows down I give it some gas. This is when the clutch breaks! I even tig welded the drum on this busted the drive rollers. Dave sent me an email stating" That nothing I am doing could possibly strip the threads out". He said " No one has ever had this problem! Then why is it happening to me? Can someone explain this is 2 kits, 2 drive rollers, 4 clutch drums, and oh yeah 2 bikes! I have all kinds of questions and I hope you all can help. Do you have to ride these things that carefully to make sure the clutch engages at the perfect speed and time? is there a learning curve or something? Are these kits not made for large hills? Should I cut my losses at this point, or is there a way I could get a dependable bike? Could I convert these friction drives into something more dependable? Any help would be appreciated!
I just want to ride my bike,
Fred
Fred
