Thank you, huge help! Now my question is, do I need one with the longer thread count with the stock head or would a shorty work?Here's a post with suitable plugs. I would stay with something from this list. Forget about those generic plugs on amazon.
http://motorbicycling.com/showthread.php?t=10560
Thanks for the info Chaz, again, huge help. I ordered the ngk bp6hs and will be delivered Tuesday (gotta love Prime). I'm thinking about getting a pull start kit, I assume it would help getting it started, plus it's only $15You can probably find this in a thread here but I would say that you only have to worry about a long plug hitting the piston. Again, stick to the list and you should be just fine.
NGK - B6HS, B7HS, BP6HS, BP7HS seem to be to be the most popular
Yeah I realized after looking through a few different ones that they're decent at best.I don't know if the pull start would help and you may have fitment issues with the pedal clearance. I don't know as I've never used one. The forum is your resource and you'll probably find some good info if you comb the threads. Experts may weigh in here with advice.
For your first start up I would leave it and stick with the bump start so you can peddle for a while if that's what it takes to fire it up.
