you gotta be kidding!
I can do the math but to really play around with gear ratios
you get smart and use this program.
Instant results.........in all permutations.
calculate speed based on engine RPM, drive ratio,and wheel diameter.
Here is your Magic. Screw Math!
gear ratio calculator can be downloaded from:
http://jimsitton.net/ratiocalc/
Just right click on the file gearratio.exe and select "save link as" and put it somewhere you can find it again.
Once it's saved, double click on the gearratio.exe file and it will run.
The program allows for up to three ratios in series.
If you have fewer just leave the unused ratios set to 1:1.
The program will also calculate speed based on engine RPM, drive ratio,and wheel diameter. Be sure to measure the outside diameter of your wheel for accurate results.
[FONT=Verdana, Arial, Helvetica]To travel one mile a 26" wheel requires 775.5 wheel revolutions.
That is the 'magic number' you have been missing for your speed math.
Your 4G transfer cases 20T/100T reduction is 100/20=5:1
Your 9T engines output to 44T wheel sprocket is 44/9=4.9:1 multiplied reduction.
5*4.9= ~25:1 for your total reduction to your wheel.
[/FONT]
@6800rpm your back wheel would spin 6800/25=272rpm.
Speed is measured in time so now we convert rotations per minute to hours.
272*60= 16,320 rotations per Hour.
Now that magic number...
16,320/775.5= 21mph@6800rpm.
Now that is @6800rpm 'spec' best power but as you know these engines can spin faster, you put out 7560rpm, just work the math yourself now that you know the math and 'magic number'.
See what just changing that 4G 9T sprocket for the 10T does on paper for example ;-}
The more gear change stages you add in the drive train the tougher it gets to do the math, but it's worth it.
My topic for 4-stroke shifter gearing is here http://kcsbikes.com/topic.asp?TOPIC_ID=942
Hope that helps.
