salorr33cc
PLEASE TELL ME WHAT YOUR BEST MAIN JET SIZE AND NEEDLE CLIP POSITION YOU ARE USING AND WHY YOU CHANGED IT,,, ON NT CARBS ONLY PLEASE, ALL INFO WILL BE CALCULATED IN A GRAPH TYPE FORM TO HELP EVERYONE WITH CARB SETTINGS WHILE USING THE NT CARB...ALL INFO WILL HELP THE MOST,,, EVEN YOUR ELEVATION IF IN HIGH AREA..
And briefly tell what is done to your engine ,,,, like exhaust type and picture or description,, light to heavy porting and polish,, PISTON modifications for piston port engine or piston REED valve engine,, what type of HEAD your using,, stock or aftermarket CDI,,
Any and all info will help like your stock came with bike MAIN JET SIZE(70 ish +/-))))) and what you are using now plus needle clip slot position and what modifications were done that you had to change MAIN JET and NEEDLE SLOT.....
Thank you all info will be calculated to try to help everyone with proper jetting..!!!!!!
picture shows old 4 slot needle and slide which is shorter then NEW 5 slot needle and slide......
