the x chamber is what made all the power i went frome abot 25 to over 40 intantly revs to top end now switching from 36 tooth to 40 tooth rear cog to try to get in the rite rpm range for the pipe next it will absoutly fly now
what does (WTF) and (BTW) mean???? i see these abbr, a lotI planned on removing the spacer (WTF?) from the intake and I kind of had a feeling that the poo poo pipe that came with it was indeed aptly named. I also had to add about 2.5in length to the intake to get it to fit the frame and I wonder if that didn't have a negative effect. It does four stoke at wot. I just torqued my front motor mount bolts in half inside the case so It'll be coming off the bike soon. Was thinking about putting it back into one of those Felt style integrated tank frames. They look a bit more sturdy than the grubee's with the hardmount. Have a feeling the frame I have it in now isn't going to cut it. This motor has already torqued 6 spokes and 2 front mounts. I will give this motor that, it is a low end monster!
Did you ever find out what size main jet?this thing has a keihin carb on it does anyone know what main jet it has in it
I need a smaller main, took the air filter off and it runs much better. Have been told it is too fat if that is the case.not yet bike runs so good i havent bothered but i think i need to be one step ritcher
