It's been a long journey building a motorized bike from a Fixie/single speed flip-flop hub frame but for all intents and purposes I'm done. I gotta give thanks to the people on this forum; You people are awesome and helped me a lot! It started as a manged mess First Build: issues, but it got there. I can see why there are recommended bikes to use as a build...
Things I had to do to make this "work" and look pretty...
To Do's:
CONSIDERATIONS:
Just wanted to share some pics of my build. If you're running into issues trying to build up a single speed/fixie, feel free to shoot a message my way and hopefully I can help.
All in all, super fun to build and even more to ride!
- Sproket welded to a fixie gear and held on with a lock ring (hub spoke number wasn't compatible with pineapple rag joint and hub wasn't shaped to take the clamp type)
- Throttle cable kit to get rid of excess length
- All cables/wires run along frame in heat shrink tubing
- Magneto and CDI connections using bullet quickdisconnects (went through 2 each in the time it took to build)
- Soldered the spark plug boot connector to the wire core
- Back brake (NEED MORE BRAKING)
- Dual brake handle with ~60/40% distribution
- Better brake pads (NEED MORE BRAKING)
- Painted random parts flat black
- Short filter (had longer angled filter before)
- Intake offset to fit filter (smoother power over stock)
- Velocity stack for carb
- Headlight
- Rear brake light
- Rear fender (rooster tail is ridic in the rain at speeds)
- Wider BB for crankarm clearance past engine casing
- Crank sproket mounted on inside to keep proper chain line
- Bent muffler to follow downtube angle
- Bent chain guide so the pulley was parallel to the chain
To Do's:
- Still can't tune carb to idle properly or have smooth power throughout throttle range.
- Better chain guide that sits in line with the chain
- Less consipicuous fuel tank
CONSIDERATIONS:
- Down/seat tube angle is horrible for mounting. You will need to bend an aftermarket front mount to get it to sit right.
- Above issue causes chainline issues. You NEED a chain guide, because the chain on the lower side of the engine sproket will hit the casing
- Make sure your hub is compatible!!!
- Wider tires would be nicer... Things are kindof sketchy at top speed on 23mm.
- Keep tires properly inflated if running skinnies. Sidewall flex is no joke and can get you into some scary situations in turns.
