Chain Shreds Tensioner Pulley
Graham
Problem: my bike chain is shredding up the pulley that came with the kit. Its properly tensioned (not too loose/tight) but still the links (master link especially) are carving it up and getting plastic gummed up in the works. Suggestions?
HEY graham. do u know witch chain idler you have? the ball bearing 1 or the cheaper "axel" one??
On my old bike the chain tentioner was wearing down but never enough to cause pastic to get in everything!.
Im not 100% sure wat you could do unless u got the cheaper one maby try and grease it up a little.
Only a sugestion
Im sure some1 here can help you.
put some wheel bearing grease on the axle going through the tensioner pully or purchase a tensioner pully with a bearing in it. Make sure the angle you put on the chain, when putting proper tension, isnt too much. Perhaps you should remove some chain links in order to have close to the proper tension before even having to use the pully, that way you will get the smallest angle on the chain going from rear wheel to engine. you should also ensure that the sprocket on the back wheel is aligned with the sprocket on the engine.
Graham,
Alignment of the chain and sprockets is essential. If you're seeing abnormal wear on the tensioiner pully, or any other part, start by making sure the chain and sprockets all align perfectly. As for the plastic wheel, many of us have abandoned the plastic for polyureathane skate board wheels. You need access to a lathe or some method of cutting a groove in the surface of the skateboard wheel wide enough to allow the chain to run through it without binding. Most skateboard wheels have bearings instead of bushings and will run for many miles without problems. There are some very good threads here devoted to the tensioner modifications that will get you out of trouble. Use the search feature and read up on chain tensioners. Hope this helps.
