Good luck getting guidance from anyone here again. And good luck starting a business building these bikes.
How many things does a motor need to run? Fuel, air, compression and spark. Do you have them all? Are they in proper order, in regards to ratios and timing? You have pointed out a possible timing issue at your magneto magnet. After rereading the entire thread, this is the only solid evidence of a hinky part. And it's only hinky, not definitely bad.
Motor mounts were mentioned likely because when loose or improperly installed, vibrations can cause cavitation and bubbling in the float bowl, robbing the carburetor of fuel, despite adequate flow and proper jetting. I don't think the motor being discussed has run long enough for you to have an issue, but I could be wrong. There's about a dozen things you may have overlooked, but you've replaced so many parts, it has to be something stupidly simple, maybe, just MAYBE your motor mounts are part of the issue.
For the love of God, your bike will not vibrate because you keep running that maple syrup viscosity fuel mix through it and soaking your plug with oil. Maybe try thinning your mix( 32:1) and add oil for your comfort after you get it running. Better yet buy a pack of opti and have a consistent mix all the time.
You last stated " 21:1 but it doesn't really matter because your last bike ran 16:1"
I call B.S and a lot of other members are going to ignore you if you refuse to listen about the basics such as a good consistent fuel mix and NO rubber mounts.
I don't think the mounts are his problem in keeping his engine running, however, rubber engine mounts shouldn't be used, they have failed too many times to the point that any debate about this is obsolete. Also, I agree that too much oil can really guck up these engines and running with a rich mix can cause problems.
It seems the problem as described is that the thing is flooding, and I suspect it's the timing, probably sucking in gas upon shut down and making it impossible to start until the gas dries out again. Check for proper timing. At top dead center the cut outs in the magnet will be in the 12:00, and 6:00 position. The key will be at the 1:00 position ensure it isn’t sheared. (there are a total of 4 keys on these engines).
http://s982.photobucket.com/user/Ron-Becker/library/Magnetto?sort=6&page=1
The ignition timing can be adjusted with an offset key. Retard the ignition timing for more high RPM speed at the cost of loosing low RPM power. Advance the ignition timing for more low rpm power at the cost of loosing high rpm speed. One can go too far and loose any benefit of adjusting the timing, but a typical offset key only advances or retards the timing by 1/2 a key width. Any thinner than that and the key will be too weak to be of any use.
Damn, insult me why don't ya. I didn't say nothing about your mounts except that rubber mounts suck...but they are your choice, do as you wish. I kinda wonder why you are on these forums at all asking people what is wrong with your little china girl engine, I mean, since you have been a mechanic for 30yrs, I would expect you might be telling us what is wrong, not asking us. Just sayin...
