exokinetic
My dream component is a knock sensor, a high definition crank position sensor, and a computer controlled ignition system that keeps the spark advance at the absolute maximum, and takes timing out when it needs too as it senses knock.
So you ride the maximum spark advance curve no matter what the conditions are.
Colder outside? Hotter? Elevation Change? Humidity Change?
Knock sensor loop compensates.
Change Fuel? Raise Compression? New Pipe?
Jetting not quite right? Yea, you will be slightly down on power, but the knock sensor loop will be giving you the maximum available power from the current jetting.
It's what makes today's turbo cars -gas and diesel- so much more efficient than their pre-knock sensor brethren.
Apollo Moto Racing is currently in the R&D phase researching the necessary components, and how to engineer a system of incorporating them into the "China Girl" type 2 stroke engine.
