Agreen
I recently bought a PZ19 carb for my little 48 and wanted to share some experience I've had with it.
A couple notes about the coolness of this carb.
a) It has an actual o-ring seal. No more leaking intake bs!
b) It has a dedicated idle circuit. The NT carb relies on the main jet for all aspects of fuel delivery, which can make the idle pretty iffy.
c) cable operated choke!
d) The fuel bowl is HUGE! You will not have any fuel starvation issues. It stores so much fuel in the bowl, I forgot to turn the gas on and made it over 2 miles before I noticed. It didn't die on me, I just happened to look down.
Just looking at it, you can tell it's a monster, compared to the standard NT carb. The NT has a 14mm diameter throat, and this one's 19mm. That doesn't sound like a lot, but think about how much more cross sectional area that is! I also checked the jet size before getting too far. It's a size 69. My current NT was running a 68. We'll have to see what it does? If anyone can explain how different size carbs compare with the same size engine and jet, that would be great.
First thing to know is that it's not just a direct swap-on carb. You will have to do (or hire someone) some fabrication. The flanges are very different.
So I got to fabbin' and noticed that while the intake port is a rounded off rectangle, the intake manifold and gasket is a 14mm circle. I fixed the gasket with a gasket punch kit (made the inlet a little more squarish) and I tossed the old Z kinked intake in the parts bin. Nothing there to reuse.
A little massaging here and there and it fit pretty well!
I got it all welded up and I spent some time with a file and dremel stones, smoothing out the inside. I probably spent too long on that part honestly. I mean, I was able to milk 43mph out of it with the stock NT and the z-kink manifold, I may be putting too much effort in to this lol.
I did notice that the bowl is not level with the ground. Not a big deal though. I put it to the test overnight with the fuel valve on. Not a single drip.
So, what's the final word? I'm not too sure. I got the fabrication done Saturday night. I went for a ride and got 20 feet before had to go home and get my winter motorcycle gear on.
Round 2 and I pulled the starter cord, and it fired right up and purred at idle. A nice, strong idle. I hopped on and pulled on the throttle and WOW it had torque. Up to a certain speed (felt a little slower) but the midrange really improved a lot.
The next 2 days I got maybe 15 minutes total to tinker. I thought that it had only bogged on me, and not 4-stroked. So I went up a jet size larger. It warmed up a lot since the day before, so no full-face helmet this time. I went out and did a full throttle run, only to experience crazy amounts of 4 stroking. So the 68 jet is too much, maybe it did 4 stroke with the 69 jet and I couldn't hear it with the full face helmet on?
So now this is where I stand. The idle and midrange are FANTASTIC! I just have to get the main jet right and keep taking it for WOT runs to see how things work out. And I'll also be grabbing up an air filter for it soon too. My CDI is getting soaked from the 2stroke spray
