Ducati250Single
I bought a 66cc Stinger motor kit over 2 years ago. I've never had a prob!em with it, other than throwing the drive chain on my maiden ride, (my fault for not having the rear wheel aligned, it was a little cockeyed), maybe I got a good kit, or what I would like to think, was the measures I took before ever mounting it to my bike. I took the motor completely apart, making sure everything looked right. One piston ring had almost zero end gap, so I filed the gap to .014", (when in the cylinder of course, ha-ha!). I made sure there were no vacuum leaks where the carb bolts to the manifold, I set the float height, (which was WAY too high). I also made sure I sealed the wires going into the motor. I lubed the piston, rings and cylinder, as well as the wrist pin bearing. I also squirten a little oil on the crank end of the rod. I also sanded the head lightly, (sandpaper taped down on a peice of glass), to make sure the head was flat. If I hadn't done all this to my motor before running it, I know for sure it would have had a vacuum leak at the carb, causing it to run lean and idle poorly, the ring with next to no end gap would have been a major problem and the high float level would have made it run crappy, SO, what happened instead was a motor that fired right up, ran way better than I ever imagined it would and idled perfectly. I realize not everyone has the desire to take their brand new motor apart, but these motors are so simple, you can take them apart and put them back together in a very, very short time. Another recommendation I would have is to use a good 2 stroke oil for your premix, and by good I don't mean you should be buying the most expensive synthetic oil you can find, oil is no place to try and save a few bucks. I run Pennzoil, and absolutely no issues with carbon buildup on the piston crown or the combustion chamber, or exhaust port. Anther thing I did was to match the transfer ports in the cylinder to the ones in the case. I had to remove a lot of material to make the case ports line up, but its well worth the effort, and yes, you must take your motor completely apart to do this. I took my motor out of my bike, tore it down, ground the ports, put it back together and had it back in my bike and was riding it in about 4 or5 hours, and I took several breaks. My motor runs strong enough now to make spoke breakage an issue...but that's another story.
