does this look right? Triangle on back of piston, pointing to the intake?
Thats not an arrow.Arrow is suppose to face the exhaust, but The piston is the same on both sides so I wouldn't see how it would make a difference. I've always done it that way though.
I am as sure as 100's of motors and quite a few boxes if those triangle marked pistons.Thanks L, that's what I've read too. I'll pull the cyl. later to be sure. Everyone agree? H.
That is right.does this look right? Triangle on back of piston, pointing to the intake?
I agree... and if you ever get a piston with no mark on the crown, the ring pins always face the intake side...Thanks L, that's what I've read too. I'll pull the cyl. later to be sure. Everyone agree? H.
It's a low wrist pin hole piston / PK 80 style.Got it, pins toward intake. Now, to determine what piston and cylinder I need to have for a rebuild, I need to measure the skirt to wrist pin distance, and/or get the number off the con rod, right? This help is more than I have ever experienced on other boards. Thank you all, H.
