mapbike
Nothing fancy here and I haven't taken pix of it since some more cleaning up and the header pipe being brazed to flange tubing, but I just thought I would share some pix of how you can make a nice exhaust flange from a washer if you have the tools and want to take the time, I wanted the "Taffy Bike" to have a large unrestricted exhaust since the mods I have done to its engine will allow it to get so higher than normal revs, the header pipe has a 1" ID and is currently 18" long, I will likely reduce the length to 14-16" if I have room to go that much shorter and still be able to mount the expansion pipe where I want it.
These pix are all of things in the rough and honestly I didn't do a lot of cosmetic clean up since the header pipe from flange to chamber will be wrapped in exhaust wrap so none of it will be seen anyway, but is is cleaner then seen in these pix now and has been sprayed with hight heat flat black paint.
