I ALWAYS remove the inner seals on crank bearings to allow lubrication.Gosh I can see you are excited about these engines!
Good for you!
I really do feel almost anyone can have more fun with these tiny little MAB motors than a fire-breathing rice rocket!
You might want to re-consider one of your improvements...
"I replaced them with high quality sealed bearings from the aftermarket."
Can't say I've come across any sealed bearings that will hold up to the heat and power / rpm that an open bearing, lubricated by the fuel/oil mix will.
But we're all looking for something better!
Please post the part number and a source if they prove to be reliable in this application.
Tnx
rc
But good thinking!
Davezilla
Re: Why is this engine unknown?
there are some good metal sealed bearings that would work realy well in these, just remove the inner seal so it can get lube from the fuel/oil mix instead of the grease that's packed in there at the factory. the outer seal can be retained to boost the efforts of the crank seals. I'll have to look up the part numbers I got and post the links, but there are a few good ones in the 6202 and 6203 sizes. The SKF bearings are also excellent and will hold up.
I think these are in fact SKF bearings Davezilla....MUCH better quality that the Chinese stockers.
