First make sure your clutch cable is routed from the handlebar to the engine with no sharp bends or kinks. Make big radius bends to reduce friction. We also suggest to lubricate the cable inside the housing.
If you used the small spring that comes with the kit that is supposed to go on the cable between the guide and the clutch actuator arm, remove it, It doesn't do anything but make the clutch harder to pull. Use the larger spring. It is a heat shield.
Make sure the moving parts behind the cover are well lubricated as suggested above. The cam in the cover as well as the bucking bar that protrudes from the center of the sprocket and the ball bearing that is behind the bucking bar.
There is a modification you can do but try these suggestions first before we get into the mod.
