YesImLDS
Hi everyone, I have a peculiar problem. I had a pretty decent 66cc motor with a type b piston that I recently replaced with a brand new 66cc motor with a type a piston. I literally just transfered over my performance parts from the old motor to the new and broke it in with extra oil in the gas and moved onto 32:1, but since I have had this newer motor it has had a really loud noise at high rpm. It sounds like an exhaust leak, but only happens when the motor is warmed up and when it does happen the motor looses just a tiny bit of power, but is hellaciously loud
The parts that are on it:
Slightly milled down stock head for higher compression
SBP expansion pipe
NT carb with .66 jet
Lightened top end (piston with holes in areas that have no ports)
Ported intake and exhaust
36T sprocket
All the gaskets are not leaking and are tightened down properly. Exhaust isn't leaking as it was just rewelded to stop any leaking. I guess I am just not sure what is wrong. I cracked it open and took a couple pictures.
This one to me looks like flaked off carbon
Same angle but with flash
Picture of milled head
The head looks like the plug color is a light brown. Notice how the head has built up carbon in the area that doesn't have direct access to the spark. Due to it being cold I try not to ride it at this point, but this noise really bothers me. It doesn't sound like marbles on tin, but if you were to cut a slice in the exhaust. I'm going to re-inspect the exhaust just incase there might be a pin hole or something, but even before it was rewelded on my previous engine is was very tame and not loud at all. Any advice?
SBP expansion pipe
36T sprocket
