Meet Mongo, a nothing special
48v 1000w hub &
15ah LiFePO4 ebike with very typical preformance, about 30mph for 30mi -
without pedal assist (obv better with);
I've ridden daily, all seasons for comin' up on three years now - the only time I was ever "forced" to pedal due to the batteries being spent was when I was initially establishing it's point of no return, it's actual real world range in real world conditions... which as I did it on purpose, doesn't really count as stranding me
Having said that, I do pedal it quite a bit out of choice, both powered (assist acceleration) & unpowered when slow isn't slow enough (riding w/HPVs) and I assure you it isn't any sort of serious drag at moderate pedaling speeds, the speed you'd likely be at trying to get back home. The faster you go the greater the drag it's true, but I figure if someone's interested in racing pedal-only, why a 1000w ebike lol
There are times in which I need even farther then my max range would allow, if it's jus' a bit - I'll moderate my throttle input w/more pedal assist & that provides a significant range extension. If it's quite a bit more then a bit, I'll jus' bring my charger & plug in wherever I went as odds are if it was that much a trip, I'm prolly gonna spend at least a little while wherever I am (like when you're at work or w/e).
As for the hybrid aspect (two stroke & hub)... it's not a particularly complementary combination if you're after efficiency as the two smoker isn't to begin with. If you're after reliability the ebike has that hands down, but dragging the two stroke around would only reduce it's range... they're a tricky thing hybrids. I built
mine simply for the sake of experimentation (four stroke/electric) & while the electric aids my acceleration, this is countered by the drag at speed (as mentioned) so it's "efficiency" is highly variable, to this day I'm unsure if I'd be better off with or without it *shrug*
All in all I'd concur with what you've already concluded, for a daily rider beater commuter, reliable & quiet - jus' the humble ebike is prolly your best bet
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
