2 2strokebke New Member May 17, 2013 151 0 0 Richmond,Va Nov 20, 2014 #1 Hello, I dont know how to fix it or is it my idle needs to be turn down? I try to turn it down but it dont helps.
KCvale Well-Known Member Feb 28, 2010 3,966 57 48 Phoenix,AZ Nov 21, 2014 #2 Most likely just a pinched throttle cable. Unscrew the throttle cab on top the carb, pull the barrel out and work the throttle, you'll find it.
2 2strokebke New Member May 17, 2013 151 0 0 Richmond,Va Nov 21, 2014 #3 KCvale said: Most likely just a pinched throttle cable. Unscrew the throttle cab on top the carb, pull the barrel out and work the throttle, you'll find it. Click to expand... Okay thanks i will try that out.
crassius Well-Known Member Sep 30, 2012 4,032 158 63 USA Nov 21, 2014 #4 also check that carb is still tight with no air leaks
