My engine works great when u keep it inside and then go and use it. It would even work fine being in the cold. However I hit some loose snow and the handle bars twisted around and I readjusted them and keep on going. Then last night I noticed it wasn't going past 33km/h. It was even struggling to get up big hills. I had to help the engine by pedaling while it was on to make it up the hill. It didn't even sound right either. Sounded a little louder then it should of and I don't know why. I checked for leaks and I can see none. The gaskets appear to be intact and not torn or worn down at all.
I'm going to take the air filter off the carb and give it a really good cleaning and see if that helps at all. Not sure if that could be holding the engine back ?
EDIT: I should add I noticed a build of ice around the covered wires and in diff spots on the bike frame. Could ice or water go into the carb or the engine and mixed with the gas ?
