mew905
Well, I hate to say it but the transfer angles were corrected on my jug and it didn't help at all. I think it may be because I got an old GT5 jug though (the head that came with it was squarer, and the combustion chamber was just a simple dome cut into the porous aluminum, not shiny at all). The intake was tiny (As is the one on my GT5a cylinder though, but the 5A is smaller, oddly), the transfer ports were also significantly smaller, and opened on a taper (for example, they start to open at 125 degrees, then at 132, the whole width is opened, then at 150 they're 100% open, top to bottom).
So I corrected the transfer angles using a small pilot hole, drilling in at a 4 degree angle, then switching to a bigger one, and finishing it off with a round/pointed double cut dremel burr, and finally a small diamond burr. Also I opened up the exhaust port width to 30mm along a chord (so about 32mm arc, or port-map width, which comes to 65% of the cylinder bore. Also chamfered the edges.
In addition, I removed the SBP flex pipe, mostly for cleanliness issues, but I didnt think it gave me any power. Upon reinstalling the stock muffler, I realized... the SBP definitely gave me more low end power, as with the stock muffler I have to pedal much longer than I used to, just to get going.
So stock exhaust (no cap, couldn't gut it though), corrected transfers, wider exhaust and intake ports (no timing changes), and reed valves with an RT carb on a 5" hose = net loss of power. It's not *much* slower, aside from off-the-line, but I'm willing to bet the SBP pipe will be a bit more effective now. Too bad it turned my nice, white, DC shoes black with oil, so I need an alternative.
The solution? Hopefully this thing will help
http://www.motorizedbicycle.ca/exhaust-system/motocross-poo-poo-pipe-muffler.html
